AntMB
With my 5G tronic (722.6) for a little while now gear change when cold could be a bit sharp with the occasional groan. If the road is clear enough I can give it some brisk acceleration and it shifts fine with no groan. Sometimes the occasional judder.
I did the gear box reset once and it worked a treat. I've tried it again and it has helped but isn't perfect.
Get it out on the open road where it's sitting at constant speed and it's fine.
Research perhaps pointing to conductor plate/valves?
What do you think?
What do you think?
