bampy525
i have a clk230 w208 model automatic,ater starting up car ,it sometimes wont move from park to drive.can anybody advise on a possible cause/remedy
That's OK then I wont be silly and ask you an obvious question then !6 years
where abouts is the brake light switch
Is this the "tip" gearbox? If so stick a pen down through the flap at the bottom of the selector gate this will release it. Don't know why it happens.
Hi Tracy,welcome to the forum,as the thread is over a year old perhaps you can tell us what model/year your car is,as you cant use the tip function(manual mode)sounds like your autobox could need an atf & filter change if it hasn't had one in the last 40,000miles or so?Thanks for the advise - I did use a pen and it released the Gear stick, but the problem has not gone away completely:
1. Once in drive or Reverse - the car works so I can now take it to a garage for servicing etc
but
2. The tiptronic function does not work, so will not select anything but D
3. If I then put the gearstick back in Parking possition it gets stuck again
Is there anything else I can do or what is faulty so I can advise my mechanic?
Sounds like it would benefit from a service/gearbox atf & filter change especially as you've been working abroad & the car i take it didn't move much why you were away?it is CLK 230 kompressor model 2000 (i think)
Yes it is automatic and tiptronic
And needs service badly - has not had its A service in more then 530 days ( I was working abroad etc and had not used the car much all that time)
total millage is low less then 50K
