Gemclean Detailing-MBclub Member Eddie01's 100K mile Mercedes C55 AMG
mikec32
Mercedes C32 AMG
Hi Guys
It’s been very busy @ Gemclean Detailing HQ, but now just before the next instalment of Top Gear, here is the write up on the long awaited write up on Eddie01’s C55 AMG.
When I first viewed Edd’s C55 AMG, I knew I was going to have my work cut out. Though the car was mechanically sound the exterior was in some desperate need of some TLC. The bumper was suffering badly of lacquer failure, the bonnet had a rock chip the size of a 50 pence piece, and the roof had some nasty chipping along the top of where the front screen meets the roof. The rest of the paint was heavily scratched and had serious signs of automatic car washing in its time. Apart from this, I believed I could restore the paint to high level though some of the defects were so deep, it would need wet sanding to bring it back to its former glory of the production line. The boot lid I could tell was seriously damaged with scratches and was on fine line weather to re paint or takes my chances of wet sanding. But the roof, bonnet and bumper were well and truly past the limit of correction and were time to think about painting. The wheels were also pretty damaged from road grime as well as the black centres looking tired. After a thorough going over it was agreed that the car would come in for a full correction detail, and wheel refurbishment. While it was with me it was decided we would re paint the roof, bonnet and bumper to pull this car from its tired look and get it back to its former glory. So the car was booked in for January for a 2 week overhaul.
To start with the roof, bonnet & bumper were repainted. Obviously the front grilles were bent and heavily chipped, so they were removed, re shaped, painted and placed back onto the front bumper. Once this was completed the intense restoration of the exterior was to commence!
This was the car prior to being detailed, on arrival at the studio:
I was refurbishing the wheels so were left dirty, though these would be the first thing I tackle on any car. The first job was to get the door & boot shuts thoroughly cleaned. For this I used surfex HD, agitated with a detailing brush and rinsed with 60* purified water. The tailpipes were then treated to bilberry & iron x and agitated with 0 grade wire wool. These tailpipes had not been cleaned in a long time, so needed some serious TLC. After the shuts, badges, grilles and traps were cleaned it was onto a double snow foam @60*c.
.....and then the boot lid:
Once the clay bar system was complete, the car was given a thorough wipe down with IPA at 30/70 to remove clay sling and any silicone fillers from the paint. This way I will see the true finish of the paint without it being masked up by old polishes etc. The car was then put on the ramp so I could remove the wheels and start the super long process of paint correcting the car. As you can see the parts we painted were in good, form and just needed refining as I prefer to do that on the car:
Then it was onto the old paint! This was a whole different ballpark as the ptg readings were all over the place. The drivers front wing and a terrible smart repair and was super sticky. The drivers door all the way around to the passenger’s rear door was harder than any nano lacquers I had ever worked with. This concerned me as it was baffling to how the lacquer got in such bad condition when I was so hard. Hence why automatic car wash came to mind. Both side skirts looked to be painted out of a spray can and the passenger wing, front and rear door and been repainted at some point too. The paint was soft, sticky and had dry lacquer runs along all rubber window seals. This car truly had been in a war and it had now been passed onto me to get it sorted. So onto the correction process full steam ahead! Here are some various correction shots of the standard super concrete paint:
Then it was time for the boot and entire rear end of the car. These places were so badly damaged you would have had to remove all badges, handles, lights etc and fully wet sanded the lot, to even get 95% correction rate. So to show this example to the owner I completely wet sanded the boot lid. The owner knew the boot lid was bad with some of the straight scratches measuring 8 microns deep. So by wet sanding, he would know it could be fixed and could choose at another date to get the entire rear of the car wet sanded.
It was then onto the passenger wing, front and rear door. This paint was super soft and marred very easily, but was also very sticky. This was a little technical as compounds clog, and too much heat can be generated under load. But as you can see below a big giveaway is how much metallic fleck is in the paint compared to the standard paint.
This was also a defect found in the front wing caused by aggressive sanding and not following up with finer papers. PTG readings were taking and were wet sanded out using 2000 then 3000.
The bonnet after some heavy inspection did have a couple of silicone marks left in the paint as well as a random scratch had appeared! This does not go out as finished work and all must be perfect, especially when the customer paid a perfectly painted bonnet. So this is what he got and these defects were removed from the freshly painted bonnet to make sure it really was perfect.
Once the 26 hours of correction and wet sanding were completed, the car was given a thorough dusting. The airline was used to blow out of the shuts, gaps, badges, grilles and rubbers. Then the rest was completed with a supernatural duster and a good IPA wipe down. This is a necessity as the car was going to be protected in crystal lacquer and unlike sealants and waxes does not bond to surfaces with polish on them.
The paintwork was given an inspection under sun gun:
Once this was completed, G-techniq C1 was applied to all painted surfaces and left to cure for 24 hours before the hybrid coating. While this was curing the glass was polished and protected in G-techniq G1, the arches were protected with aerospace 101 and the callipers were degreased, cleaned and protected in C1. The wheels were completely refurbished, given a full IPA wipe down and protected in G-techniq C5. They were then placed back on the car and torque up to the correct factory setting. It should be said now that this dark blue on the C55 did not suit IMO black wheels. So I convinced the customer to have them finished in 2013 MB silver to the very highest standard. As you can see right down to the brush lines in the diamond cut finish are perfect. Just needs some new centre caps now:)
Once this was completed the tyres were dressed to matte finished, exhaust tips polished, door shuts polished and rubber seals protected. Then to finish G-Techniq EXO was applied to the paint, glass and wheels to add longer protection and mainly for its excellent properties of water repellently. The car was given a final inspection under sun gun to make sure there was no excess product left on the paint.
And then this was the final outcome, all 100,000 miles of it:) enjoy!
With this level of protection I warranty for 45,000 miles before the protection even starts breaking down, and will also minimise wash marring and light swirling. A great way to put a car behind the most durable protection in the world. No gimmicks at all. This was the next car in after the C55 and will be a write up for another day.
This week shows another MBclub member 993 C2S in for correction detail and C1 crystal lacquer.
So till then hope you enjoyed and all comments welcome
Kind Regards
Michael
Micheal
Hope you don't think I am being funny, but could you do something about the size of your pics on this and future posts? I'm sure they look fantastic on your huge monitor but the vast majority of your audience have 15" laptops or 17" external screens.
Would love to view your work but it's just too difficult.
Thanks for listening! :thumb:
Hi, not at all. If someone can let me know how to do this I would. As the problem is when I'm taking these pictures my customers want full size images so they are put on the Internet at this size. So having to resize each one then putting them back onto the Internet would be time I just don't have. If there's a simple/quick solution than fantastic:)
Kind Regards
Michael
Kind Regards
Michael
Thanks. Afraid you would indeed have to resize them. But think of it as a good investment both in terms of being a good forum member and also in terms of more people being able to look at your work?
I would love to, but resizing that amount of photos would be time I literally don't have. It's taken me a good 3 weeks to find an hour to just put this up. But I completely und,rest and what you are saying, so will have to come up with a plan of action:)
Blown away by the final outcome! I for one welcome the larger image sizes so you can see the finer detail...
Kind Regards
Michael
Fantastic work.
Thanks for posting. :thumb:
YES Mate! Who does this quality of work in New Zealand, anyone you know of...??
iOS app resizes the pictures automatically - is this something more to do with the web based front end on this forum rather than something the OP needs to fix? Quite nice to have such hi res images IMO given the subject matter.
Great work.
Excellent and good to see my old C55 getting some proper love. You can really see its midnight blue as well - a quite gorgeous colour.
Hi Charles
Thanks for the encouragement, I'm still loving the car and have further plans down the line, at this stage I'm just looking forward to some nicer weather and driving it, I'm back in France this month and it's snow or rain every day, can't really enjoy a C55 in such conditions.
I will drop by at some point if you're around for a chat and general catch up ?
Eddie
Eddie
With pleasure - you are most welcome, pop in whenever, although not sure the weather today is good for any vehicle locally!
Pressing 'Ctrl - and +' solves the problem. Super images and write up. :thumb:
resize photos
Very nice work mate, not sure you really should or need to resize but you could do it in photoshop very quick and easy anything from 2 to 202 images and more in one go, with one click or imageresizer for windows just a right click away it’ll do you whole folder
