General help with 2003 CL600 Bi Turbo
bennybelmont
Leeds
2003 Cl600 Bi Turbo Renntech, 1999 BMW 530d SE
Hello
I hope someone can help? I am looking at replacing the brake discs/pads on my Cl. I have had the wheels off and all looks quite straight forward? As it's a Merc i assume it may not be as straightforward as it looks? Do you unbolt the callipers wich then allows the disc removal or do you need STAR system to deactivate various brake sensors etc?
Also the drivers side speakers don't work is it simply a loose wire or the amp is broke, i have tried the fader on the radio but no difference?
Finally! Sorry! The tensioners need replacing i have bought a set and new drive belt, i also have Alldata DIY program that shows how to change them but doesnt show how to access them as tried from above but no room, does the car have be put on ramps and all done from underneath?
Many thanks Alex
The brakes are normal in operation, no Star requirement.
I would have thought the disks could be removed with the pads out.
The wiring loom can break due to the complex door hinge on the CL.
Thank you for the help so far, brakes no prob, speakers sounds like door card needs to come off to see if wires are broke?
