stigsblade
- Sep 1, 2008
Have removed head from my w124 e300d (606 engine) according to very helpful info on here. having spent £600 on parts (Gaskets, head bolts plastic parts) and recon etc I just want to make damn sure I get the reassembly right! I have the following questions;
1. Is there a way to check if injectors are ok, and what torque setting is required when I refit them.
2. Is there a recommended procedure for tightening head bolts and what torque setting is required.
3. I am going to use original glow plugs + one new one, they came out ok and they glow red when tested. Is there some compound which will make them easier to remove in future and again, what torque setting is required.
4. The gasket set came with a bag of smaller seals and washers, it is not clear where they belong. i presume they were either missing from the old assembly or have been introduced as a mod. How necessary are they?
Finally, my computer will not allow access to the russian site, am I alone in experiencing this?
Your help as ever will be hugely appreciated.
