Gentle Words of Caution. 124'S
trapperjohn
Lancashire
124 300D 24V Estate
Every now and again you know you have to do some routine maintenance of a more than the normal kind, even to these noble beasts.
So up for change were the rear subframe bushes both fore and aft of my 124 Estate. I may add that the milage is now around 227K and this car works for a living.
So the parts were ordered from ECP, this was my choice. Merc are shoving up the prices of 124/190 parts on a too regular basis for my wallet. They were promptly delivered and at an agreeable price.
The car then went up on the lift and the rear subframe was removed. Whilst the frame was off the mounting points for the frame were given a detailed inspection. Rust and pin ***** holes were found in one of the mounting points for the frame and also in one of the wheel arches. These were welded up and made good. Also the brake lines and hydraulic lines were attended too whilst they were most "getatable" The whole of the under rear end was treated whilst the frame was off too. The old bushes were "popped" out (yeah right, various methods of extraction were applied) And the new bushes popped in.
At the front end, new track rod arms were fitted.
The car now "wafts" better than ever before.
The very week before my car was fettled as above another 124 Estate was in and was found to have a sub frame mounting point that had sheered off completely. It was rattling like "billyo" against the underside of the car held in place by the subframe.
So beware you 124ers. If you get a chance have a good look at your underpinnings.
Big thanks to Ian and the Team at 124 Works:rock: for sorting this and for keeping at it when the job "grew legs"
I think Ian has some pictures of the job which he will put up when time allows.
CHEERS
Edit. The naughty word police did not like pin p r i c k. Wow and this in the technical section too.
carat 3.6
In the workshop
S124 E300d wagon, W124 om606 monster, E46 v8 coupe
I need to have a look at mine at some point, but it's on the daily driver so she's got to earn them first. Depending on what it's like under there I may do some waxoyling while I'm at it.
OP
OP
trapperjohn
trapperjohn
Lancashire
124 300D 24V Estate
Missed a bit and Silver Saloon reminded me of it in his post about subframes.
Remove the rubber bung from the rear subframe mount and fill it full of waxoyl. We did that too.
grober
MB Master
Perth, Scotland
W204 ESTATE
There was a thread not long ago on here where the guy described doing a welded repair on the rear subframe front mountings- complete with pics will see if I can find it.
Olivier
Edinburgh
E300 TD
I had mine repaired and welded few years back at the chassis where the subrframe attached, it was totally rotted, you could pock some hole through it with a screwdriver, and the car was only 11 years old at the time, this tell something about the way they build mb...
Howard
MB Club Veteran
Toad Hall
CLS 500 / A 150
The w124's are very well built.
I had the same thing with my rear subframe mounts . The underseal cracks in time and allows water to flow along the crack into the mounts.
Had it all welded up , good as new. There is a thread on it somewhere.
EDIT : i should clarify , this was on my old w124 , not on the CLK's or the A class.
A160DSB
Canvey Island, Essex
A160 BRABUS Metallic Meteor Grey
I think thats what happened with my A160... I know he welded the sub frame to the rear chassis
benzers
North of London
230TE, but mum had a new 230TE in 1984 (W123), (not the same one) mines a W124
Good post! Need to bear this in mind too.
BillyW124
North West London
W124 E320 coupe, W211 E320 V6 CDI, W211 E63 V8 AMG, R129 SL 280 V6, W215 CL 600 V12 Bi Turbo.
i think that thread is called 'my 124 she's back' or somthing.
stwat
Sheffield
1989 W126 300 SE
We have had a few members over on the 190 forum with snapped subframes in the last few years !! They are basically the same as the 124 subframes so peeps do indeed need to keep an eye on corrosion in this area now that the cars are getting on in age.
millo777
Swansea, Dubai, Riyadh
1997 W140 S600L/2003 S211 320cdi
Thanks for the heads up. I need to get a break pipe and fuel line replaced, so and Ideal time to drop the sub frame and replace the bushes at the same time.
Were the sub frame bushes from ecp any good? anybody know the main dealer prices for these?
OP
OP
trapperjohn
trapperjohn
Lancashire
124 300D 24V Estate
ECP parts were what I fitted at my request and they appear to be more than up to the job.
Main dealer prices were very "heavy" compared to ECP. Try Franey on here too he has some good deals going.
