Don't blame them one bit.
Similar thing happened years ago at the US GP.
Lets hope something is sorted. These tyres have put a damper on " to the limit racing". It's more pacing than racing at the mo!
That kerb has been there for years and has not caused any damage before, so why now?I think Gary Anderson of the BBC summed it up perfectly. The drivers are rubbing the inner edges of the tyres on the outer edge of the kerbs, causing the excessive wear and tyre failure.
The drivers are flaunting the rule that says they should not have their car cross the white line on the edge of the track by claiming they still have a wheel (at least) inside the line.
QUOTE]
The drivers aren't flaunting any rules
That same kerb has been there since 2009 so is it an amazing coincidence or is it because Pirelli's new 2013 tyres are crap... mmmm I wonder
Stick armco or walls on the bends. Job done.
Now they are complaining when they pick up damage .....
Aw, diddums. Put up a physical barrier - they ain't going to want to hit that.
Pirelli did say that all the cars which suffered failures were running the rear tyres the wrong way round
I thought Pirelli did all the mounting and had a specialist in each team garage!
Tony.
They do however they forgot to tell the teams they were asymmetric and could only be put on the cars one way round
I think the teams knew that all too well and decided to mount them back-to-front in order to get more heat into them quickly.
The teams forgot to factor in the directional attitude of the steel belts.
Now the important question. Did the teams ignore the directional advice and were, in effect, running their cars illegally ?
