Hello guys can anyone help with this annoying problem I have… changed the springs on my Vito for 30mm drop Eibach springs, the amazing difference on the fronts with reduced body roll and handling but I’m getting a knocking from the rear when going over bumps/holes … Basically all roads in the UK these days.
Changed the rear dampers for new ones at the same time … should I have opted for a non-standard damper ??
Should I of changed the plastic spring mount plates ??
Any help greatly received, as I said the fronts are amazing but the rear is doing my head in.
