GLA Front Headlight Case
c43amg84
C43 AMG Coupe
The Mrs crashed into our bin on the drive and cracked the headlight cover passenger side, the headlight itself is fine but needs the plastic case replacing. Is it possible to get just the plastic case and not the full headlamp? I have called Mercedes Parts team and ordered what I thought was the correct item (turned out not to be) and they have quoted me over £600 for a new headlight.
Does anyone know if I can just order the clear case from anywhere?IMG_0118.jpg
It's a sealed unit and you won't find a "glass"/case for it. You need a complete headlamp I'm afraid.
OE salvage GLA nearside units start around £70 on ebay....be sure to check part numbers, seller feedback & any returns policy if going down that route. No idea re any different units depending on spec, year etc. Maybe check any part is from a RHD car as not sure if market designation a beam pattern factor.
HTH
It looks like a static LED headlamp and these are not the cheapest.
ebay
autodoc
