ive an icarsoft mb2 it doesnt even scan glow plugs. so which scanner did you use ?
Well I am sure your Icarsoft does tell you what glow plug is faulty,my one did twice,it gives you what one it is so you have the choice of changing the faulty one only and I had the i980
Well if you look at the very first post,the op says I get this light up that then go's, that light is a glow plug not working,if that happened on your car with the diagnostic scanner you have it will tel you which plug has stopped working,as far as I know it will be in the DTI's then all you need to know is say where number 5 failed glow plug is and if you have a V6 diesel looking at the engine from the front the left side from front to back is 1,2.3 and on the right from the front 4.5.6 of course it is very simple if you have a straight 6 diesel,you have possibly the best Mercedes scanner for personal use you can buy.
