When turning the ignition on the Glow plug light comes on for a few seconds and then goes out as normal.
The car starts first time after the engine turns a few times (a bit longer than I would like but it’s been like this for a while now)
After around 20 seconds the glow plug light comes on again and stays on for 1 minute.
I connected an ODBII reader and surprisingly it didn’t show any errors! Either my reader is faulty or something else is not right. The ODBII software shows the RPM etc so there is definitely a connection there.
From videos I have found on the net they say the code told them exactly which glow plug was faulty
Any ideas?
What is the safest way to cause an error code so I can test the OBDII reader? Can I pull out a sensor connector some where?
Any guidance will be appreciated…
Any ideas?
