Glow plug light
poppypiesdad
Cupar Fife
Vito 108 Dualiner
Hi all done a search and found out that when it stays on after starting
108cdi Vito 2003 Old shape
that it is either
the battery
glowplug /'s knacked
could the relay be sticking on
and where is it located
looked under the front seat next to the battery but couldnt find the correct one
can anyone help pls
and does anyone know where the central locking relay is located
ta again
jamie
If the glowplug light stays on its most likely one or more faulty glow plugs, best to test them and if one is faulty replace the lot.
is there any reason (apart from may aswell replace all at the same time) you should replace all rather than just the 1 faulty one?
Its a pig of a job
You need to get them out to test them anyway
Parts not expensive
If they break off in situ absolute ba*****d of a job to remove
apart from that ?????
jamie
