leicschris
- Jul 10, 2014
- 2001 w220 320cdi
Hi All
car - 2001 W220 Mercedes S320cdi
The issue I have is that I have no glow plug light in the dash ever, and have had recent starting problems, although not this week, but the dash light is still not working.
I have changed the relay/control module for a used one which I was told was working, and changed the temperature sensor for a genuine Mercedes one, which seems to have helped the starting first thing in the morning although I am worrying about the winter.
Today I put the car into Mercedes Leicester for a star report and diagnosis, which did not seem to be any help at all. I didn't understand the service reception guy who didn't seem coherent in his definition, or inspire confidence in his knowledge and Mercedes seemed keen to keep their technicians to themselves!
They told me that at first a fault showed with glowplug number six on the star and as I had used a second hand relay/control unit that when they tested the car with a new control unit all the faults went away on star but they couldn't get the glow plug light to light on the dash.
They don't know why the dash bulb will not light, and said they had the instrument cluster out but someone previously had done something to the cluster and they didn't know what, so they would change the instrument cluster.
I can accept the possibility that the relay/controller could be suspect even though the breaker told me it was tested and working but I don't understand what could have been done to the cluster that Mercedes looking at it couldn't tell what it was.
Asking a simple question like "Is the bulb blown", "Was there a bulb there" and "Is the glow plug light a separate bulb in the cluster, or part of a unit" couldn't get a direct answer from the service receptionist, just we don't know what is causing it, but the must be an issue somewhere!, Yep, that's why I was there!
It is my understanding that the main ECU looks to the engine coolant temperature sensor and depending on the answer it decides to power the glow plug relay to turn on the glow plugs, and to turn on the glow plug light on the dash. It is for this reason that I changed the temperature sensor in case it was sending false readings to the ecu.
I would have thought it would have been quite easy for Mercedes to test a bulb and/or determine if the relevant wires were showing power to the connector, and that any previous bodges would be obvious.
I would remove the cluster myself and look but the dealers wouldn't sell me the removal tool and the one I bought on ebay which said radio key is not up to the job and is too thin and wont remove the cluster.
Any ideas guys
Chris
Any ideas guys
Chris
