If you have need to remove a glowplug from a CDi engine, be careful. They are rather fragile and thinner than in previous engines, 10mm as opposed to 12mm. No matter how careful you are when trying to remove them, it is quite possible to break them, leaving them stuck in situ.
The only recourse, it seems, is to remove the head and drill them out. Mercedes know it's a problem (local stealer admitted last week they're averaging 2 a week) but will not cover it under warranty, unless the plug failure occurs after an unreasonably short time.
