SmartAmg
MB Club Veteran
Yep, seen that, but he might want to post other pics.NOTE : OP has changed his profile picture to the photo of the actual lamp seen on the dashboard. Post #16
Or might want to put the correct pic into this thread, and update his profile pic back to something more preferable.NOTE : OP has changed his profile picture to the photo of the actual lamp seen on the dashboard. Post #16
Or Screenshoot the pic, it shrinks it, quite a lot, then post it.
How’s that mateOr might want to put the correct pic into this thread, and update his profile pic back to something more preferable.
Yeh I’m starting to suspect this Also mate , sure I’ll get some pics up shortlySounds like a cooling fan issue to me, can you check voltage when the engine is hot to see if the car is attempting to power it and test the fan itself.
For pics, I use this Upload Image — Free Image Hosting. You can upload and then simply paste the code into the thread, then click the Preview button at the top right of your post to make sure it's how you want it to appear before committing. There are loads of ways to get images on the boards but if you attach them, you run out of storage really fast or as you've found, they are too big. Hope that is of some help anyway and best of luck resolving your issue. The members here will no doubt help you out but diagnosing at this distance will need some pics
