Good merc mechanic Surrey area - basic!
charan_singh
Guys,
Have some quite basic problems with the C124, wondered if anyone knew of a reasomably priced, honest mechanic that I could contact?
problems:
window regulator
general service
cold start valve needs a look / distributor cap
brakes need review
fuses need a look
indicators out
Easy stuff....:)
Guys,
problems:
window regulator
general service
brakes need review
fuses need a look
indicators out
Easy stuff....:)
Where abouts in Surrey?
Go see Olly at PCS in Horndean. As honest as they come, highly competent, knowledgeable and very good prices. Worth the trip down the A3
Totally agree 100%! Can't get any better.
you do not have a cold-start valve and NO distributor.
can you not see the small valve (2 inches square) on the nearside inner wing marked with MOT on top ?
put hand on it or listen to it after car has reached full operating temp and see
if it is ticking at 2 beats per sec. It should be. If not, then a problem and needs to be replaced or cleaned out.
Is yours the 6 cylinder or 4 cylinder engine ? out of interest.
for basic work on a W124 Try Carserve - and he's mobile and ket my E320 C124 sweet for 2 years.
Carserv - Mobile Mechanic & Car Servicing
Ask for Charlie.
EG Water Pump Replacement £150.00
Replace Bushes - £90
Overhaul Electric Window and Realign and rebuild washer jets £90.00
for basic stuff, I'm impressed.
Ask for Charlie.
thanks mate - wheres that gear knob?! ;)
Oh, OK. I will have a look for the item you have mentioned. sounds like i need a haynes manual!
Car is a 220 - 4 cylinder.
