aquanaut
Although, make sure you check all electrical items such as heated seats etc. I had a few issues which would have cost a fair bit if it wasn't for merc warranty
sports disc or not they dont have ridges across the surface lol the surface of a disc is smooth there will be an amount they are aloud before they are classed as f**ked! like were i work at daf they are aloud to be 1.2 mms deep on say a cf 85 but there is no way the surface should be un even that is wear ( but may still be in tolerance )they are sport discs look it up
Guys,
I have a chance to swap my 05 plate 3.2 V6 TT Mk1 plus £5750 for a 55 plate C55 with 45k miles. Now to start with it sounds easy, take the C55 and live happily ever after!
However, I am fussy and mean real fussy. My TT is like new and I really mean it and it only has 16k miles on the clock.
The C55 does not come without issues and I am just not sure if they are enough to bin the idea. I do realise though C55's don't crop up every day!
The issues are:
1. All 4 wheels need a refurb
2. Tracking is out a fair bit.
3. Both rear Tyres are nearly shot.
4. Rear off side caliper looks like it may be sticking or something as the rea disc has a rusty ring towards the outer edge so the pads obviously not making contact under braking, any ideas??
5. The two front discs look warped to me, however you cant feel it under braking at all, but they are not flat to run your fingers over and visibly look strange. Here is a pic:
So what do you guys reckon to all of the above???
sports disc or not they dont have ridges across the surface lol the surface of a disc is smooth there will be an amount they are aloud before they are classed as f**ked! Like were i work at daf they are aloud to be 1.2 mms deep on say a cf 85 but there is no way the surface should be un even that is wear ( but may still be in tolerance )
that is total rubish lol i have 330 mm ap raceing discs on the front of my cosworth that is used as a fast road / track car its has no ridges wearing into the disc surface leading from the cooling hole lolGet that C55 and and ask if it comes with a box of Kleenex.
The discs look exactly like my fronts and they are fine. Earlier poster said drilled discs do stripe on the drill hole patterns. Not really an issue.
read the post lol the brake discs wearing like that as that is what discs with vent holes wear like! that is what brake discs that are becoming worn out wear like vent holes or not lolIt's total rubbish that he has a C55 or total rubbish what he is saying about the brake discs?
Lol
Lol
