Green 2 pin plug goes where?
Littledigger
Manchester
CLK 2004 270CDI
I've just removed the inlet manifold on my clk 270 cdi (pre facelift) to remove the swirl flaps and after re installing the manifold and stuffed the wires through the middle, I have a green 2 pin plug that I can't remember where it plugs into. It's on a short wish wire but just can't find where it plugs into. I've connected the sump sensor, the starter wire, the top of gear box plug (crank sensor I think) but at a loss to where this 2 pin plug goes. does anyone have a sensor diagram?
SOLVED. Still don't know what it connects to but I solved the problem by getting under the car and reaching up above the starter to have a feel. found the socket for the plug.
