Grind sweet W124
Discussion in 'Engine' started by benzers, Sep 15, 2011.
  1. benzers
    benzers Active Member
    92
    Aug 7, 2011
    North of London
    Car:
    230TE, but mum had a new 230TE in 1984 (W123), (not the same one) mines a W124
    this is about a 1991 230TE, that I'm learning to respect, she was poor, though getting there.. So today's question is about grinding.
    When I start her up in the morning, the first 10 meter's of driving she makes a grinding noise that is coming from the from of the car, it definitely sounds like metal agains metal, but after that its gone. until the next morning.. I'm not turning the steering as I move..
    thank you in advance.
  2. Ian B Walker
    Ian B Walker MB Enthusiast
    7,672
    Jun 7, 2003
    Freckleton
    Car:
    300-24, saloon and coupe, E300 24 valve diesel estate
    Possible brake / disk issue?
  3. BoyracerAU
    BoyracerAU Active Member
    218
    Apr 4, 2011
    Sydney South
    Car:
    1985 W123 230E & 1994 R129 SL500
    A bit of surface rust on the brake discs is probably all it is.
  4. grober
    grober MB Master
    27,891
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    I would be looking at the rear brakes- possibly the rear caliper spring clips or pads or alternatively the handbrake shoes/return springs in the little drum brake that forms part of the rear disc. The rear brake assemblies are often heavily corroded and prone to jamming on.
  5. OP
    OP
    benzers
    92
    Aug 7, 2011
    North of London
    Car:
    Thanks for all the swiftissimo responses.
  6. EDZ649
    EDZ649 MB Enthusiast
    4,001
    Jan 25, 2009
    1066 Country
    Car:
    R129 SL600 V12
    Oooh, I do like a bit of grinding in the morning ;)
    Agree with the above ^^^
Share This Page
