GRP Advice
Discussion in 'OT (OFF Topic) Forums' started by imadoofus, Dec 31, 2008.
  1. imadoofus
    imadoofus MB Enthusiast
    2,859
    May 16, 2005
    Car:
    This and that.
    I have a fibreglass panel 60cm x 120cm (3mm thick), and I need to cut it lengthways. The cut is curved.
    So far, it seems the best method is a Dremel, but I could do with some advice.
    Is it best to cut wide of the line and then sand back to the mark? If so, what should I use for sanding?
    Am I better off with a (manual) coping saw?
    Plus any other words of wisdom you may have.
    PJ
  2. rf065
    rf065 MB Enthusiast
    4,053
    Jun 8, 2007
    Grossbritannien
    Car:
    SLC300 - C250d Estate 4 Matic & Z900rs
    Use a facemask is the first thing that comes to mind.
    Russ
  3. OP
    OP
    imadoofus
    2,859
    May 16, 2005
    Car:
    This and that.
    Take it as a given that I'll be getting Mrs D to seal me securely into a dustbin bag before I start. ;)
  4. andy_k
    andy_k MB Enthusiast
    5,204
    Apr 23, 2003
    Bexhill, East sussex
    Car:
    Alfa GTV 3.0
    any saw will pull the laminate away from the matting unless it's incredibly sharp and very fine in which case if you are using a hand saw it will take you hours
    A dremel with a rotary cutting disk will do a decent job but following the curve may well prove tricky.
    If it were me, I'd use a jigsaw on a slow speed with a fine cutting blade and tape over the area you intend to cut. Work steadily, don't let the blade get hot and be prepared for a little filling afterwards
  5. OP
    OP
    imadoofus
    2,859
    May 16, 2005
    Car:
    This and that.
    Fortunately, I reckon the curve can afford to be less than perfect, so the Dremel is the way I'll go.
    PJ
  6. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,412
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    Dremel is my single most used tool now... Its so bloomin useful.. to think i didnt have one 6 months ago..
  7. andy_k
    5,204
    Apr 23, 2003
    Car:
    Alfa GTV 3.0
    dremel and it's big brother the angle grinder - indispensible tools
Tags:
Share This Page
