chriss428
- May 3, 2010
- Location
- somerset uk
- w124 230e manual white amg kit+ Yreg W210 E320 Tekiti Grey 7seater hadGina w124 E200te blue 7seater
right if you guys have been following me then you know where i am, i have been having problems passing 5,000 revs on my manual 230e which has now turnd into flatspot missfire when warm!
I reluctantly changed the leads n plugs which did make a slight differance but still got hurendous missfire so i cleaned the idle control valve out, again no differance i looked at the dizzy cap and arm the cap looked quite good but im not sure about the arm i cant remember if the arm is ment to have contact material on it or be clean metal?
so if the arm isnt the cause what else can it be?????????????
cheers chris
cheers chris
