Crazyjester900
Hi guys can someone tell me the difference between these two bulbs?
Thank you
Brad
Thank you
Brad
The H4 bulb has two filaments in it - one for dipped beam and one for main beam. The H7 just has a single filament - so if you have these for dipped and main beam you need 4 bulbs.
My car can take both,
That was the whole point of the thread
to tell me which i should get
Is that definitely true for an Aussie-spec car? I dunno...If you have a 1996 W202 your car should use H7 fitment bulbs, the fittings are totally different.
H7 it is..
does just changing the bulb really do much?
i was thinking the full kit with ballast etc..
cheers
Brad
H7 it is..
cheers
Brad
Sorry Brad, I'm only just getting the gist of this...H7 it is..
Yes I believe they are championing the arrival of the external combustion engine!1850's??
