pstock
I have a split inner CV boot on my driver side rear axle, a couple of questions, (2001 CL500)
1/ is the half shaft a simple pull out from the rear diff or has the diff cover to be removed as i've read in some other threads ?
2/ What grade oil would be recommended for the diff (if i have to drain it to remove the cover) ?
thanks in advance
Paul
thanks in advance
Paul
