handbrake release
shorif2000
London
w220 s500L
I have a c200 Komp 52 plate. The handbrake release i have to pull 5-10 times for it to work. is this normal at this age? 92k mileage.
is it an expensive repair?
OP
OP
S
shorif2000
London
w220 s500L
it releases the brake but i have to pull it alot for it to work.
BlackC55
Portsmouth, Hampshire.
E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
I expect the adjuster under the seat needs lubrication and adjustment.
OP
OP
S
shorif2000
London
w220 s500L
is it something i can do myself?
Dave Richardson
Plymstock Plymouth
C Class 220 Evo CDI and a W176 A class 180 cdi
If the same as a coupe, lift the rear seat & you'll see an oval plate secured with a small number of 8 or 10mm bolts, undo these & lift away the cover plate & then you'll see the adjuster in all its glory lubricate & adjust, simple job mate:thumb:
DSM10000
Near Salisbury
E32O CDi Sport, MX5 1.8 Sport, RR 4.2 SC
Depending on model the seat base may be secured with 4 bolts. Suggest a spray grease sparingly applied, WD40 is really not much use, it has poor adhesion.
