MJJ
- Jan 13, 2020
- Location
- Wiltshire
- '09 S211 E220 CDi manual - 197k miles and counting
Morning all,
I am considering a swap from our existing, 25 year old, non-condensing oil boiler central heating system, to an air source heat pump. This is in a 70s detached house with radiator only heating, not some wonderfully insulated modern marvel, but we will improve the insulation if we practically can. EPC survey says we are band D, and would benefit from cavity wall and an additional 50mm loft insulation.
I am mainly wanting to do it from a reducing fossil fuel point of view. I don't want to spend fortunes on the change, and through the Green Homes grant scheme, it is a significantly reduced capital investment these days. I am not expecting the monthly bills to reduce greatly, I am expecting to simply replace oil bills with electricity and continue to source renewable electricity. The capital investment case does benefit from the fact that our oil system is old, and will likely need replacement in the not too distant future anyway.
My question/concern is around real world heating and hot water performance with an ASHP. I am told by the various installers that a few larger radiators may be required, but other than that, the ASHP can still provide plenty of heat capacity, even in winter. Everything I read from the ASHP manufacturers say they work most efficiently heating water to c. 40 degrees, but my belief is that our oil system is heating everything to 60 degrees. That seems like quite the reduction in heat output to me.
Anyone got any real world experience to share?
Thanks,
Martin.
Thanks,
Martin.
