Peter James
- Feb 23, 2017
- 2005 clk320 convertible
Hello everyone this is my first post as I have just joined the forum.
I have just bought a 2005 clk 320 convertible it's a lovely car.
The car has afew electrical issues that I hope someone can help me with.
The main issue is that the seat belt assist for the passenger doesn't work at all ,there is no motor noise but there is resistance when you pull it out manually.
The driver seatbelt assist works fine.
The next issue is that the headlight washer is not working ,no motor noise when the button is pressed and the lights are on, slight dimming of dashboard so I think the switch is OK haven't checked volts on motor.
The last issue is drivers headrest will not go down with the switch, it goes up ok and goes down when the seat is tilted forward and sometimes is does work after the seat has been tilted.I have looked on the forum for the headrest issue and will look at the motor pcb.
Sorry my first post is asking for a lot of information from you guys but any help will be great.
