Over the last week the radiator light on my '89 2.6 auto has been coming on. The coolant level did drop by about 2 inches after topping up, but there was still coolant clearly visible in the expansion tank and the car wasn't running hot. It was booked in for a 12K service today so I just kept an eye on it.
I used the car to go to Windsor Races last night and was stuck in a crawling traffic jam for about 30 mins. The temp rose higher than normal but went no where near the red.
Today I brought it to the independent I use. He was busy signing in other customers so I checked the expansion tank to see if there was any difference. The COOLANT (I emphasise the word coolant), acid greeny yellow in colour, was 2 inches low but apart from that all was well.
Get the call to pick the car up this p.m. "Any surprises?" I ask. "Yes, the ATF is mixing with the coolant in the rad. A new rad is needed." I go over to pick up the car and the expansion tank is now full of bright red ATF. I say how can this be, when I checked it this morning it was full of coolant? Nothing red at all.
They don't know what happened. No idea. The mechanic who worked on it said the expansion tank was full of ATF when he opened the bonnet. They say the rad has a small leak (hence the drop in level) anyway so I'd need a new rad in any case. In fact, lucky me, I have two problems which can be fixed with one new rad.
Apart from the timing being amazing, in that the expansion tank filled up with ATF in the time between me leaving the car & the guy opening the bonnet, there was water and ATF in the "dimple" on the top of the expansion tank and splashes of something oily below the ex. tank. They said they added no fluids.
I KNOW there was no ATF in the expansion tank when I dropped it off. I checked the fluid level on the garage's forecourt while other customers were being dealt with. I can understand the thing breaking and I'd accept that if they'd told me it happened on a road test, but to tell me it was like that when they opened the bonnet is just not believable.
It is especially not believable, I've just noticed, because the service was carried out at 80,290 (from the invoice) and the mileage is now 80,305. I live 5 miles away, which means THEY ROAD TESTED MY CAR FOR 10 MILES AFTER DISCOVERING THE FLUIDS WERE MIXING.
Should I give a big sigh, light a ciggie then roll over and fall asleep? After all, I feel like I've been rogered good and proper.
What do you think?
What do you think?
