Petrol engines this time that mysteriously reduce emissions under certain conditions.
From German magazine
It will be very interesting to see how this one develops!!Petrol engines this time that mysteriously reduce emissions under certain conditions.
Wouldn't surprise me either. It also wouldn't surprise me if other manufacturers do the same. That said, even without cycle beating or cheating, the exhaust emissions from cars vary depending on how they are operated and under what conditions.Wouldn’t surprise me...
Perhaps they should be tested at wide open throttle up a large incline after not being serviced for the equivalent of a few years as many owners will run them in real life.Wouldn't surprise me either. It also wouldn't surprise me if other manufacturers do the same. That said, even without cycle beating or cheating, the exhaust emissions from cars vary depending on how they are operated and under what conditions.
The main problem with all of this was the continued adoption of test cycles that were unrepresentative of typical 'real world' driving. Another issue is that there is no official definition of what constitutes real world driving or how real world exhaust emissions should be measured.
This is changing with the new world harmonised cycle, but so called real world driving is still a variable feast.
There's nothing easy about emissions testing and nothing easy about calibrating engines to operate well for customers and at the same time meet emissions limits that have been derived from data generated using an unrealistically light driving cycle.Please, please
Real life?
That would decimate the industry and create a taxation vacuum
Lets stick to the unreasonable and unrealistic if we can, much easier all round
You'd be surprised how little operation time is carried out a full load in real driving.Perhaps they should be tested at wide open throttle up a large incline after not being serviced for the equivalent of a few years as many owners will run them in real life.
You clearly know a lot about this... thanks for your insight.As I say, unreasonable and unrealistic.
If it was easy to make cars that meet the current emissions criteria, it would be done.
It's easier and cheaper to set up the cars ecu to cheat, so, they are set up to cheat . . . .simplz
Customers want cars that have decent performance. Emissions regulations are a very big push in the other direction. I do agree that the OEMs should not use cycle beating algorithms and should be penalised if they do.Manufacturers have been carefully tuning engines to meet emissions limits since the days of carburettors which went lean in the late 70's/early 80's causing minor flat spots as a result. The difference these days is the underhand way in which the test cycle is detected and emissions reduced solely for the purpose of the test. If manufacturers are still doing this they should expect to get the book thrown at them. It's not as if they are at their strongest financially after Covid so to continue cheating could be a death wish which takes some of them under.
I’m not even sure it was underhand, because it wasn’t a secret held amongst a very, very small group of people working for a single manufacturer. I would be surprised if any manufacturers didn’t do it.
