kalvin928
- Jul 10, 2013
- Location
- Watford.UK
- S205 C63s , Lotus Carlton replica, CLK 200 Kompressor
Hi all
got battered up 1.4 petrol Skoda estate which I use for work, its had quite a hard life and ever since I have had it (2 years)there has been slight oil leak... I normally don't need to add any oil for a couple of months and this is even with a daily commute into and around London. my main gripe is that the oil eventually saturates the alternator belt and then hey presto its all shredded like spaghetti ( 2 days ago) garage has said that head gasket needs changing (£400) debating whether to get it done and then keep hold for at least another year or chucking it in and buying another one? I had brakes done around 3000 miles ago, and serviced etc. but the £400 cost is causing a dilemma in that do I fix or replace car? I thought about using a gasket sealer? ok its not permanent fix but if it prevents further seeping and keeps the oil in/ back for another year, then may invest in a tub?
also must say that I don't have any issues relating to overheating/ losing water...
