Headgasket types E300TD
Ali E300TD
Islamabad-Pakistan
W210 300TD om606.962
Hi!!
I've got an E300TD 98 year 606 engine. I got the head gasket replaced and ever since then its normal operating temperature has gone to 90-95 instead of 80 ....
I was wondering if different head gasket types are available, with different thicknesses, in this engine.. like in many other cars.
If thats the case how can i tell what thickness was my old gasket and whats the new one... are there any notches or any other mark that represents the thickness?
Thanks in advance!!
All the same gasket. The temperature should be controlled to 80c by the thremostat and then the viscous fan if it gets that warm.
So you are saying its not the head gasket?
My mech says it is altho it does not mix coolant and oil, he checked it by pressing the upper radiator hose which was pressurized at normal operating temperature...
He says it should not be like that!
Take the cap off and see if it's bubbling combustion gasses into the water and perform a compression test.
It is possible that a piece of scale got disturbed in part of the water gallery when the head was off and is now caught up in the thermostat causing to not open fully.
Thanx!! i'll check the expansion tank for gasses and what figures should i get for the compression test?
I may be stating the obvious here but use a compression tester for diesels as the petrol ones wont work. As for pressure, I am, not sure but a figure of 11 bar comes to mind.
You need a minimum of 400psi/27Bar, at 300psi/20Bar it won't start at all.
Check across all cylinders and see if any are significantly different, especially ones next to each other.
As Ian says use a diesel tester, not a petrol one, otherwise......it won't just be the engine that's broke..
Thanks for the correct figure Will, my apologies for wrong info.
I suspect you had petrol figures in your head as opposed to diesel ones.;)
