Petrol Pete
Hardcore MB Enthusiast
If they are Xenon's there will be no manual adjustment available to the driver.Thumb wheel headlamp adjuster by headlamp switch
The main reason is that traditional HIDs (Xenons) don't come-on quick enough, so are not good for night driving when you frequently need to switch the main beam on and off.Xenon's for driving beam and H7 for high beam in the same headlamp is common.
All a bit academic at the moment as OP does not even know what headlamps are in the carThe main reason is that traditional HIDs (Xenons) don't come-on quick enough, so are not good for night driving when you frequently need to switch the main beam on and off.
Some setups do have HIDs for high beam, but still have also Halogen for quick flashes.
LEDs have no such issue so can be used for both.
Sorry, my bad, got that the wrong way roundIf they are Xenon's there will be no manual adjustment available to the driver.
Road legal are the Ultra 5000k H7's , I'll post some pics up later with stock , Ring Xenon 130 ( Night Breaker and Philips X-tremeVision beaters ) and Ultra 5000k .
What fitment is the sides ?
looks like the main beam and high beam are two separate lamps as opposed to a dual filament bulb like on most cars ?
Sides I think are W5W
Indeed!... I've tried a number of different LED's in my sidelights (and they're a bitch to change unless you're a gynaecologist!!)
