Headlight replacement on a w207 2016
Ferrari7288
London
W212 E63 - AMG Facelift
Hi guys I’m in a bit of unsure situation, I bought a car with a damaged headlight and the previous had bought an “original” headlight for it already but wasn’t replaced. I took out the previous headlight and all the units (2 units) and I placed them on the new one, however the main beams don’t work. The LED/Blinker is fine.
Thank you!
It may well need coding in and adaptations made to beam height and beam angles etc.
I’m running a diagnostic to see what comes up but yeah I think it needs coding
More so if they're the intelligent ones 👍
Because it shouldn’t give an error about “Electric fault” if it were coding or I might be wrong
B is body
U is ECU controlled device
Only xentry or star will help here.
I have figured out a way to code it however I can’t enter the datamatrix code? Has any ever used a diagnostic device to code their headlight???image.jpg
Pressing F3 doesn’t do anything
