Headlights
angelsdisco
Burnley, Lancashire, England
Mercedes C class 2.1 Estate
What type of headlights does my Mercedes C class estate 2007 have fitted? are they reflector or projector type? I need to know so I can upgrade the bulbs to either LED or HID
Chrishazle
Nr Ashford, Kent
2008 S204 C220CDI Elegance Estate Auto, 2008 R171 facelift SLK280 Auto.
Chances are your car, like mine, has headlights designed for standard halogen bulbs so fitting LED or HID bulbs in the existing units is not an option - and would be an instant MoT fail - there's loads of discussion on here about upgrading headlights. Only realistic option for you is upgrading the bulbs to Osram Nightbreakers or similar (which is what I have done both to my current S204 and my previous S203).
OP
OP
angelsdisco
angelsdisco
I have just had the headlamp lenses professionally cleaned and got Philips H7, Xtreme, Extreme Vision +130% Headlight Bulbs fitted and can hardly see a thing at night when vehicles coming other way
Gazwould
Everywhere
C250 CDI
I'm guessing you have a projector housing for dipped beam , whilst they do have a better beam pattern the design does sap the light output Vs reflector housing .
The Philips Xtreme Vision +130% are quite old now and have been bettered .
Both tested in the same reflector housing
Blobsta
Maidstone, Kent
S202 C43 Wagon
A photo of the headlights would help us to identify whether you have reflector or projectors.
Projectors look like this:
Reflectors are these:
I imagine you have reflector units but we're all guessing until you confirm either way matey. If it is fitted with reflectors then you can only change the bulbs for what you have or as Gazwould posted the Osram NightBreakers. Different people have a different take on them, personally I don't want any reflector headlights ever again as now I've had good projectors and I can build my own lamp upgrades I see it as a backward step. I have to also state that my eyesight in low-light conditions isn't what it was when I was younger so perhaps the effects are less noticeable to me. You may have a great experience with a simple bulb upgrade of course, many people do rate them but it's really only you that can say.
OP
OP
angelsdisco
angelsdisco
which ones? OSRAM 64210NBL-HCB NIGHT BREAKER LASER H7, Halogen Headlamp Bulb for Passenger Car, 12 V, Duobox (2 units) : Amazon.co.uk: Automotive or Amazon.com: NEW 2018 SILVER OSRAM H7 (499) NIGHT BREAKER SILVER SINGLE BLISTER : Everything Else
Blobsta
Maidstone, Kent
S202 C43 Wagon
So do you have reflectors or projectors?
Two links you have pasted are 1 for a pair of bulbs and 1 for a single bulb but on the USA site???
Watchcame430
Previous 1994 SL500, 2001 W210 E430 and 2003 Designo S500 Current 2005 S211 E270
Just bought a 2005 E270 and the headlamps are shocking too.
Wondering if they are faulty they are that bad.
Been a long times since I owned a car without Xenons so maybe it is me.
To improve the beam i was thinking about getting upgraded bulbs.
I see the Osram Night breakers are recommended above. Has anyone tried these?
Watchcame430
Thank you. Bought some of the Night breakers. Will try them out tomorrow.
Thanks for the advice!
