Neil Mackay
- Nov 17, 2011
- C32 AMG Estate
Weird one for you!!! C32 drivers side seat switch.....ignition on.....switch will illuminate when switched on (first with the single light then double when that is switched)......if switched off will no longer illuminate if switched on again (on either one or two lights) unless I switch off the ignition and then switch it on again......but this doesn't work every time! I'm aware of the seat pads giving up ect but the light not coming on is irritating....I've had the switch panel off and the connectors are inserted on the back as are all the connectors in the seat control module! Anyone shed any light (no pun intended) on this?
