Heated rear window/switch flashing
pepper&boulou
EastKilbride
Volkswagen Passat V6TDi estate
Hi guys my heated rear window switch warning light has started flashing as opposed been constant when turned on. Never noticed it doing that before is that normal or am I just paranoid. I've just had a thought my lecky aerial comitted suicide during the icy weather, motor would not switch off so I disconected the earth as it was doing my head in .it was annoying any way, I never listen to the radio just the cd so it going up when not needed is not much loss , but anyway do you think disconnecting the earth has caused the above. :confused: :eek: :confused:
Steve_Perry
Wales, U.K.
CLS350CDI Grand Edition
If your rear demsiter switch starts flashing it means your battery can't deliver enough juice for the demister to work. Could be a sign that your battery is on its way out. Is it flashing only if the car is idle? or does it flash if you're driving down the road too (i.e. with the engine revving). Either way nothing to panic about, just a sign of a weak battery. Also when you say you disconnected the earth, I presume you mean for the aerial only.
S.
OP
OP
pepper&boulou
pepper&boulou
EastKilbride
S.
steve
Bought new battery 8 months (heavy duty) ago switch flashes all the time regardless of engine speed ,thought the wire was only connected to the aerial will reconect it see if makes any difference .Do yo think alternator is on its way out, car starts first time, lights not dim, checked fuses, look ok!
Steve_Perry
Wales, U.K.
pepper&boulou said:
steve
Hmm, strange, in that case the easiest test is to reconnect that earth then and see if all becomes normal again. It could be a shared earth I suppose.
Otherwise I am at a loss. Sorry mate.
S.
OP
OP
pepper&boulou
pepper&boulou
EastKilbride
S.
Cheers anyway Steve, they say two heads better than one. ;)
NormanB
Portsmouth UK
W210
In theory - yes, but a greater probability of head gasket failure ;(
NormanB
sym
North London
W204 C220CDI Sport
LOL !
P.S. this is electronics forum material . . but I can't move it :(
S.
moved it for ya! -Shude
OP
OP
pepper&boulou
pepper&boulou
EastKilbride
NormanB
How do you come to the conclution that faulty rear demister is caused by head gasket failure? :eek: :eek: :eek:
Steve_Perry
Wales, U.K.
It was a joke to your two heads comment. :D
S.
OP
OP
pepper&boulou
pepper&boulou
EastKilbride
S.
Thank god for that I NEARLY HAD KITTENS :eek: :eek: :eek:
jimmy
Northamptonshire
Discovery 3 TDV6, Discovery 300TDi - Plaything!
Yes, definetly a low voltage problem. Had it on mine and replaced the battery. For some reason my car had a low capacity battery for the spec so I fitted a really big one and now have no problems.
It is designed that way so as not to discharge the battery even more, if the battery voltage drops to below 10 or 10.5 volts (I think) then you start to get all sorts of problems with ECU, ABS etc.
marcos
Hertfordshire
C43 estate
If it's very cold, ie the glow plugs are working their nuts off, and I put the heated seats on straight after starting the engine they tend to flash for about 5secs. Looked it up in the handbook and as said above it points to low voltage.
OP
OP
pepper&boulou
pepper&boulou
EastKilbride
must get battery checked ,as I said its less than 8 months old. :mad:
OP
OP
pepper&boulou
pepper&boulou
EastKilbride
:confused
Had the battery checked its A ok putting out nearly 14 volts , reconnected aerial earth made no difference so just disconected power wire to aerial kept earth on. its back to the drawing board guys. :confused: :confused: :confused:
Thmsshaun
Ontario, Canada
2009 C300 4Matic, 2012 Kia Sportage, 2015 Triumph Tiger800 XCX
Hmm. I know Im dragging up an old thread here but did you ever get the problem sorted. I have had this with my 202 and thought it was the switch. I got a replacement and found it didnt help.
Then on removing rear trim panels and parcel shelf to fit some new speaker I noticed some corrosion on the terminals to the rear window. Give these a clean and job done. No more problems.
Hope it helps if not usefull for other people.
