heated seats
Discussion in 'Interior' started by richardken, Jan 9, 2009.
  1. richardken
    richardken New Member
    4
    Jan 9, 2009
    doncaster
    Car:
    clk cabriolet
    hi just bought 2008 clk 200k cabriolet, pretty good spec but it does not have heated seats, wiring loom in place to seats how can i tell if seats maybe heated but not connected???
  2. whitenemesis
    whitenemesis MB Club Veteran
    16,376
    May 7, 2007
    Car:
    Lexus RC300h F-Sport 2019
    Wires and connector hanging from under the seat?
    Are the seats leather?
    You would also need switches. I'd be surprised if the heater pads were present just not connected..
  3. A210AMG
    A210AMG MB Club Veteran
    8,475
    Mar 15, 2007
    England
    Does amaze me that people who originally spec the car didn't tick the option (£350 or so)
    Can you see any wires under seat, I think fitting the buttons would also require a new trim part.
    It must be possible to do it but not sure on the costs.
  4. OP
    OP
    richardken
    4
    Jan 9, 2009
    doncaster
    Car:
    clk cabriolet
    yes the seats are leather
  5. A210AMG
    8,475
    Mar 15, 2007
    England
    Sorry welcome along didn't see it was almost your first post.
    Think the heated pads will be cheap enough, but the trim, buttons and the labour would unless you are very handy be quite costly.
  6. OP
    OP
    richardken
    4
    Jan 9, 2009
    doncaster
    Car:
    clk cabriolet
    thanks for the welcome
    how do you take the switches off the console to see if wires are present??
  7. A210AMG
    8,475
    Mar 15, 2007
    England
    Sorry I don't know someone may be around to tell you soon,
    Busier on a work day the forum also....
    You could look under the seats for spare wire with connectors or similar on them?
  8. whitenemesis
    16,376
    May 7, 2007
    Car:
    If the switches are anything like the 203 then it's a control module with all option available but not switched (if that makes sense). You will need to fit a completely new switch bank, expensive.
    Also the heat pads are part of the leather covers (on the 203) so if you want to keep it OEM you will need new seat covers.
    Are you mistaking the seat adjustment loom for the heater?
    Either way would have been a lot cheaper to spec it from the factory...
  9. A210AMG
    8,475
    Mar 15, 2007
    England
    I'm guessing the OP bought the car second hand?
    Is that right? or else ticking the option on the order would have been far easier :)
  10. OP
    OP
    richardken
    4
    Jan 9, 2009
    doncaster
    Car:
    clk cabriolet
    Hi every one
    any one know of any post fit heated seat fitters??
  11. lynall
    lynall Hardcore MB Enthusiast
    3,169
    Jul 31, 2008
    Kent
    Car:
    The silver one.
    Search as someone recently had heated seats fitted to his c class with all the proper switchs but using the carbon heated pads from e-bay.
    Lynall
Tags:
Share This Page
