heated wing mirrors ?
Discussion in 'Electronics' started by 2003-c180kcoupe, Sep 28, 2011.
  1. 2003-c180kcoupe
    2003-c180kcoupe Hardcore MB Enthusiast
    123
    May 30, 2011
    Car:
    c180k coupe
    was just wondering were heated wing mirrors an optional extra on my c180 coupe ?
  2. neilrr
    neilrr MB Club Veteran
    6,265
    Jul 20, 2004
    Car:
    Various.
    Would have thought it was a standard item.
    W201s had them as standard from the late '80's.
  3. Benzowner
    Benzowner Hardcore MB Enthusiast
    2,599
    Jun 21, 2004
    Bristol
    Car:
    Qashqai Acenta Premium 1.6Diesel
    If the car is newish to you, you will find out when winter comes:D There is no seperate switch for heated mirrors, I think it is with the heated windscreen, but not sure on that.
  4. OP
    OP
    2003-c180kcoupe
    123
    May 30, 2011
    Car:
    c180k coupe
    The mirrors were misted up earlier in the week for the first time since I bought it. They didn't de-mist themselves . Is there any way I can check if they are heated or not without taking the mirrors apart ?
  5. Dec
    Dec Hardcore MB Enthusiast
    4,475
    Jul 28, 2004
    Car:
    C180,A.
    If you touch the mirror with the back of your fingers you will feel heat from the glass in about 30 to 60 seconds, that is, if it is a cool enough day. When the glass gets hot enough… after about 2 minutes?... to demist the mirror, the heater element on the back of the mirror will turn off, it will continue this on off cycle while the ignition is turned on.
    Dec
  6. OP
    OP
    2003-c180kcoupe
    123
    May 30, 2011
    Car:
    c180k coupe
    Thanks , if they are heated they are not working . Would they have their own fuse ?
  7. Dec
    4,475
    Jul 28, 2004
    Car:
    C180,A.
    The could be sharing a fuse with other consumers OR it is simply too warm for them to come on, wherever you are at the moment. Ignition has to be on for them to work, check them late at night or early in the morning when it will be cooler.
    Dec
  8. neilrr
    6,265
    Jul 20, 2004
    Car:
    Various.
    Do they come on when you turn on the rear window heater?
  9. flowrider99
    flowrider99 Hardcore MB Enthusiast
    2,542
    Aug 25, 2011
    Hertfordshire
    Car:
    SL500
    I thought they only came on when the rear window heater was turned on.
    David
  10. nigel cross
    nigel cross Hardcore MB Enthusiast
    2,410
    Jan 8, 2005
    Surrey
    Car:
    W164 ML350 Audi S4
    Me too
  11. mr. shr
    mr. shr Hardcore MB Enthusiast
    1,879
    Apr 22, 2004
    As Dec says, they'll only come on if ambient temp is low enough.
    There's no swtich, they just come on when outside temp is below (I think) 15 DegC.
    What was outside temp when you tried this?
  12. OP
    OP
    2003-c180kcoupe
    123
    May 30, 2011
    Car:
    c180k coupe
    I can't remember if I put the rear window heater on or not ? I will give that a try when this heatwave is over . Thanks
  13. flowrider99
    2,542
    Aug 25, 2011
    Hertfordshire
    Car:
    SL500
    Are you sure........all my previous cars (not Mercedes) door mirror heaters only ever came on when I turned the rear window heater on as far as I can remember.
    David
  14. mr. shr
    1,879
    Apr 22, 2004
    One of the many reasons why you switched to MB I feel. :thumb:
    1 person likes this.
  15. neilrr
    6,265
    Jul 20, 2004
    Car:
    Various.
    OP, have you RTFM?
  16. flowrider99
    2,542
    Aug 25, 2011
    Hertfordshire
    Car:
    SL500
    I knew there was a reason! :D
  17. BlackC55
    BlackC55 Authorised Forum Sponsor Authorised Forum Sponsor
    18,743
    Feb 8, 2007
    Horndean, Portsmouth, Hampshire, Southsea
    Car:
    C43 AMG with a 55 engine and supercharger, E55 AMG, S500, etc
    They come on at temps below 15degC. They come on automaticly
  18. jaymanek
    jaymanek Authorised Forum Sponsor Authorised Forum Sponsor
    16,400
    Nov 29, 2002
    Nuneaton Warwickshire
    Car:
    They only come in at below a certain temp... 5 deg rings a bell so they wont work at this time of year.
    The only way to tell for sure id by checking your spec so post either your reg or vin (or pm me) and ill check it.
    EDIT: I see olly posted the correct temp is 15deg...
  19. OP
    OP
    2003-c180kcoupe
    123
    May 30, 2011
    Car:
    c180k coupe
    thanks olly and jaymanek looks like the problem is solved :thumb:
  20. OP
    OP
    2003-c180kcoupe
    123
    May 30, 2011
    Car:
    c180k coupe
    or not , its been lower than 15degc this week and they definitely aren't working.
    i have checked all the fuses i could find and they are all ok :confused:
Share This Page
