Heater gone berserk W202
Dave280
W202 C280 V6
Hi all, hope you can help.
Got a C280 W202.
I seem to be getting hot air out of the heater at all times. Even turning the knob to the end of the blue sector doesn't seen to make much difference.
Any suggestions?
Thanks in advance
Dave
OP
OP
D
Dave280
W202 C280 V6
I've just realised, I may have posted this in the wrong section - sorry.
Also just done a search - :eek: - I know.. should have done this first.
The Duovalve looks to be suspect (split diaphragm?).
Can somebody tell me where it is (engine bay, or buried under the dash?)
Dave
racall
london
Black R172SLK
Give the two valves a tap.They are located by the brake master cyclinder
OP
OP
D
Dave280
W202 C280 V6
Thanks, Racall.
I'll give that a go tonight... and let you know.
DrNick
If you've omly got one heater temperature control then you've only got a monovalve! Duovalves are for dual zone systems. Presumably the same principles apply but probably cheaper for monovalves!
Nick
Steve_Perry
Wales, U.K.
CLS350CDI Grand Edition
Nick
From what I have seen on the W202, cars with the standard a/c get a dual zone system... two manual thumbwheels to control temperature in the left and right hand side of the cabin. However, cars fitted with the electronic climate control pack get a single zone system. There are one set of buttons to control the overall cabin temperature. Therefore I guess if you have a/c you get a duovalve whereas if you have climate it's a monovalve.
S.
