Hope this is in the correct section - electrics?
My heater motor won't completely switch off!
Had motor replaced as it was duff in January, and ever since, even with the rotary switch set to zero, you still get airflow through the vents (forced), even though it's quite gentle. Turning the switch up through the numers, you can here the fan going faster.
Yesterday, Andy Gayle changed the resistor pack on the back of the motor, and it made no difference, so the original was re-installed. As he said, this only leaves the actual switch. Has anybody else had a problem like this, and maybe give me a pointer?
