Heater slow to heat up in 1991 W126 500SE
Roygarth
Norfolk
1983 W123 230E
Takes about 15 minutes to get lukewarm and about 30 mins to get hot? So not much use!
Any ideas on what is wrong?
Thanks in advance.
Could be a failing thermostat.
(cheap and easy)
What temperature does the car run at when cruising?
Mine has always been the same - never gets REALLY hot . I've had the duovalve apart and checked it is operating and not choked , the electric circulation pump next to it is also working , drained , flushed every which way and re-filled the cooling system : result - an absolute INFERNO of heat from the heater like I had never experienced before when running with the halfords two-part flushing agent and afterwards with just water , but as soon as I put anti-freeze in it went back to being lukewarm ??? I've done everything but change the thermostat and will try this but was reluctant to throw £30 of anti-freeze down the drain so left it as it was . I know it can't be much that's wrong though .
Engine always does and always has run at normal temp .
Sorry , double post as I got ' flood control' message first time then discovered post had gone anyway !
