Heaters not blowing hot air
Discussion in 'Electronics' started by emc4raz, Sep 23, 2018.
  1. emc4raz
    emc4raz Active Member
    68
    Oct 26, 2013
    slough
    Car:
    c220 cdi sport coupe
    Hi just put the heaters on my w204 c220 and not hot air comes out whatsover, winters coming need heaters
    Any thoughts why it could do this
  2. whitenemesis
    whitenemesis MB Club Veteran
    16,536
    May 7, 2007
    Car:
    Lexus RC300h F-Sport 2019
    Cold engine?
  3. Happytalk73
    Happytalk73 MB Enthusiast
    6,000
    Sep 10, 2015
    Uk
    Car:
    Vito
    Low on coolant?
  4. Ted
    Ted MB Enthusiast
    5,758
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    Thermostat gone?
  5. clk320x
    clk320x Hardcore MB Enthusiast
    10,116
    Sep 27, 2016
    United Kingdom
    Car:
    W211 E320 CDI, W212 E250 CDI, W203 C32 AMG
    Faulty climate control unit? (Unit where you select temperature/fan speed etc.)
  6. mercmancdi
    mercmancdi Active Member
    535
    Feb 18, 2012
    Templepatrick
    Car:
    mercedes E320 cdi sport ,vw Tiguan R line , M B cls , bmw convertible
    Start with cheapest , see if thermostat is stuck open.
    Also what’s the temp reading
  7. OP
    OP
    emc4raz
    68
    Oct 26, 2013
    slough
    Car:
    Car will be at 80 -90deg, i have tried various settings on the heater control, coolant has been topped up
  8. OP
    OP
    emc4raz
    68
    Oct 26, 2013
    slough
    Car:
    literally no hot air at all, just cold
  9. Major774
    Major774 MB Enthusiast
    1,883
    Sep 6, 2012
    Car:
    W211 E55 AMG
    Sounds like you have air in the coolant system and just need to bleed it.
    Not sure how to bleed the system on a Mercedes at the moment.
  10. grober
    grober MB Master
    27,860
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    [​IMG]
    The W204 heater/ air con system has an auxilliary heating matrix which should power up until the engine has reached heater operating temperature? Could be the sensor/ element / fuse /relay /controller.
    Pre heater element
  11. OP
    OP
    emc4raz
    68
    Oct 26, 2013
    slough
    Car:
    so i did also notice the temperature hovering around 60deg and than going back up to 90
Share This Page
