Hello there, '98 C180 advice?
paddington
Potential C180 Espirit Sport
Hello there, another newbie looking advice, seen myself a beautiful '98 C180 and wanting to get her at the end of the month. Just hoping someone can help me with what to look for, she's a manuel with 84k on the clock. My dad has had a few but if there is any main pointers you can give me I'd really appreciate it and hopefully I'll be an owner of a very nice Merc at the end of the month,
Cheers guys :)
NW_Merc
Banned
Over here, sometimes over there
1994 Mercedes C180 classic
Check the wheel arches as they do rust but look how bad they are and whether you will need to treat them. Same with the boot lock area and along the bottoms of the doors.
Check all the electrics work such as electric windows and sunroof (if it has one as motors can be expensive).
A-AvantGarde
South Bucks
2016 BMW F86 X6 M, 2016 BMW F30 320d, 2001 Mercedes C320 Elegance
In terms of electircal components, the front wiper is also a common failure point...
trapperjohn
Lancashire
124 300D 24V Estate
Central Locking and alarm too. Make sure you have a minimum of two working keys. Last time I looked they are 120 pounds plus each.
OP
OP
P
paddington
Cheers guys, yeah I've noticed rust on other models I've see about, this one is silver and it tends to stick out a not more. Never even though about the electrics so I'll check those, the car has a full ticket as well so I can't imagine any major dramas with it but will give you a bit of feedback during the weekend when I go to look at it ;)
Nasco12
Twickenham
W202 C240 1999 Green; Previous: W202 C200
Check that the boot lock works on the blade part of the key. These can seize and if the battery (which is in the boot) fails you've got problems...
NW_Merc
Banned
The problems arent major as you can get power to the battery via contact points in the engine bay but it's alot more hassle
Spinal
Uxbridge
Smart, S320 and C180 with 3-pointed stars amongst others
Front wiper: This is a common issue - but if it's just slow it's easily resolvable with some grease
Rust: Wheel arches and around the locks
Locks: Check the boot lock and passenger lock both work with the key, many have never been used and as such seize
Antenna: Regularly fails (mine went through 3)
Engine: Viscous fan is a common failing point
Hope this helps :)
M.
