ChrisRed63
Hi all could really do with some help / advice regarding my Auto motor.
Had some issues driving recently on motorway suddenly no acceleration no gears, turned ignition off all good then kept happening repeatedly. To cut a long story short we checked transmission oil (fine) replaced the conductor plate in gearbox and adapter plug.
Gearbox still erratic and not always changing gear, now when I have taken off the battery negative terminal briefly and reconnected- the gearbox runs silky smooth with no problems once I switch off the engine and start off again the erratic gear change comes back
The battery is the original so will probably need replacing but rather than spend out immediately I have hooked a spare battery up to original and the same is happening.
Any ideas from anyone would be greatly appreciated - what to do next.
No codes currently coming up either?
Thanks in advance Chris
