Help aftermarket replacement Tpms sensors for S211 E55
Kwan88
Merc
I currently have a 2003 S211 Merc E55 estate that has a factory fitted tpms. i need replacement sensors as its likely the battery on them has expired, will be checking on Star to confirm.
However I am trying to find cheaper alternatives than the £90 for oem parts which are Huf Rde001 and the dealer has confirmed a merc part of A0008223306
Does anyone know or tried if other brands fit the car such as Mobiletron Ready to Fit TPMS TX-S001 will work? My research has led me to believe that other brands will work but I only need two sensors and my others are Huf will this work?
https://partsdb.info/autopart/huf/rde001
Regards.
Im sure there must be alternative manufacturers out there that work, when I looked 3 years ago I couldn't find any so I ended up replacing them all with the genuine MB part which with a discount worked out cheaper than buying elsewhere.
good luck and let us know how you get on.
When I bought my CLS AMG just over a year ago it had had all its wheel sensors removed as it had a set of 20" aftermarket alloys. Wanting to replace the wheels with OEM AMG wheels and get the TPMS system working again I found a company that did sensors I specifically used the I-Sensor, and they work perfectly.
i-Sensornederland , TPMS sensorventielen voor de auto
I bought them this company have used them several times and always very quick delivery would recommend them.
https://www.tpmswarehouse.co.uk/
