HELP, battery flat, cannot open boot to get at it.
manofgresley
Swadlincote
CLK 320 Elegance Convertible
Hi all.
I already have one thread live at the moment regarding a Wiring Diagram for my CLK 3209, W208.
I know have another, while trying to investigate my cigarette lighter and illumination bulb not working I have run down my battery, I cannot open the boot lid to get at the barrety to re charge it, my door key does not work either, has anyone got any ideas as to open the boot lid or charge the battery from another point ??
DSM10000
Near Salisbury
E32O CDi Sport, MX5 1.8 Sport, RR 4.2 SC
There should be a positive and negative terminal in the engine bay for jump starting, you can connect a charger to these.
Dec
C180,A.
attachment.php
D
Deleted member 37751
Guest
Common problem; you need to press the handle at the same time as turning the key blade.
OP
OP
manofgresley
manofgresley
Swadlincote
Hi, sorry no handle only key
Dec
C180,A.
If the key turns counter clockwise in boot lock, to about the 11 o’clock position then the lock is not seized.
  • Turn key to about 11 o’clock position.
  • While key in 11 o’clock position, push the key/lock inwards.
  • Boot should open.
Dec
OP
OP
manofgresley
manofgresley
Swadlincote
Hi all.
Many thanks for all your help, problem solved, Terminals found under bonnet, connected charger, battery at 100%, engine starts, scroll through everything, open boot lid, all ok.
Again many thanks
