PJayUK
- Oct 6, 2008
- Location
- Surrey, United Kingdom
- ML320 W163, E320 W210 & Jaguar X300-XJR6
Morning all
Just a quick question (hopefully )....
For the last few hundred miles, I have noticed that I am getting a slight vibration through the pedal on the W210 when braking at slow speed (ie. less than 10mph) accompanied by a faint droning or whining noise that seems to come from the offside front hub.
I don't think its the gearbox as its there if I select N and brake while coasting. Doesnt sound like a whining diff either and I wouldnt expect a diff issue to cause vibration that could be felt through the brake pedal anyway. There is no wheel wobble or vibration during cruising etc only when braking and its only noticeable at low speeds. No clunking, rough gearchanges or any other nastiness!
I am thinking a brake issue or at worst a wheel bearing, any opinions?
Is it worth whacking on a new set of front discs?
