Help fault warnings on EPS, ABS, BAS
gpfalcon
wrexham north wales
mb e320 avantgarde
Hello people where do I start, I have a 2001 mb e320 avantgarde v6 petrol, went shopping yesterday left car in carpark when i came back car started okay but would not disengage from park display showing 3 faults EPS, ABS and BAS. Used a tool in the gearlever to disengage from park and got the car home where i looked under the bonnet, the only thing I noticed was that the assembly just in front of the brake master cylinder (not sure what its called) was very hot? Heres hoping that someone can offer a bit of advise.
Thanks people please excuse my rambling its my first post
yes under the brake master cylinder their is a black box three electrical connectors in it its the BAS unit they can take water on the w202 and i have changed a few in the past
it removes the bas asr light
the esp light im not sure
i would also check battery voltage when engine off and with engine on looking for 12 + when off and 14+ when engine running
also lock your steering full to the right then left with engine running it might help reset it
That's the duo valve for your hvac.
yes your right thats the heater valve
i was on about the BAS unit behind it can go faulty and cause a bas asr fault
swap one from scrap yard and check if gone a quick fix no need to reset with star
Tried the lock to lock no change, will try to look at the black box tomorrow thanks guys:thumb:
Hi trevor my name is dan and im new to the forum...
I am very interested in the c36 amg you have for sale...
I am from cork myself so if you could give me a text or a ring on 0862592292 i would greatly appreciate it thank you..
Would be willing to give cash in hand as long as the price is fair...cheers
