Help finding AMG W124 part numbers??
Dee-124CAB
West London
Mercs Mercs Mercs....
Hi, need some help in finding a couple of AMG part numbers, tried the Russian site but seemed to have hit a brick wall! And the dude at my local dealer is useless, cant even use the system properly that he's been trained/paid to use.
First up i need the part number for the loom/wire that connects the Gen2 AMG foglights to the loom of the car, shown in the link below in the second pic down & numbered 59....no sign of a P/N....
Êàòàëîã
Secondly I need the part number for the correct one piece ///AMG badge that would have come on the E36...
I have come up with three numbers which I thought corresponded with the 3 types of AMG Badges, but the one I need is incorrect for some reason.
Here's what I got so far,
Early badge: A.M.G- 2018170315
One piece: ///AMG- 2108170215
Three piece: ///AMG- 2208170815
I got all these of the Russian EPC site, but the second one, the one i need is inncorect , or so the guy at the the dealer says.
Any help in assertaining the correct numbers would be mucho appreciated.
Cheers Dee
EPC gives part No for harness as..............
#59... H-WA 140-540-01-08. (there are two of them, one each side?)
Refers to it as 'high beam headlamp' (not that that's any help. They have some stupid names for things)
footnote says...from ident No 020765, also on B891779 - C020763 with code 859
In the same pic is an AMG badge #71. Is this the correct one? It is...H-WA 140-584-01-43
Don't take this as verbatim without your vin number.
Im assuming that the AMG badge numbered #71 is the little one that sits on the front spoiler...
I need the one for the rear boot lid, the one that may be the one i need is in the last pic and numbered #128..
Cheers Dee
#128 comes up as 'not valid for this model'.
For the sake of search I'm using WDB124052______ as your vin number.
Are these last 052 correct?
Sorry let me make it clear, my car is not a E36 AMG, its a more humble W124 Cabriolet, im adding the E36 AMG kit to the car, hence im finding it hard to obtain the right part number for the correct badge.
There is no 052 in my vin number.
No probs. #128 is H-WA 201-817-03-15 Which is the 'early one' as above. Find one you want on the Russian site and I'll try and find it on the EPC.
I think you will find that they are not in fact foglights but spotlights/driving lamps. The foglights on a 124 are actually incorporated in the headlight cluster.:)
My bumper lights come on when I switch on full/main beam.
I searched through all the AMG variants with the EPC filters switched off and 'One piece: ///AMG- 2108170215' comes back as fitted to the tailgate of a E36 TE estate. Looking at the (admittedly poor) picture it would appear to say AMG without the /// in front.
Thanks for all your help Druk , the one I want is defo out there, I think put Akash one on his coupe, so they are out there, I will have another go with the epc site, if that fails I will ask Akash if he still has the part number lying around on the off chance...
Will let you know if i stumble across any more numbers.
Cheers Dee :thumb:
I found this Pt. No. for the AMG front spoiler badge I believe its for the C36, Its not a number you have posted, it might be the same as what you are looking for, though not sure if its still available, hope its of some help, H WA104 584 01 43
