Sep 29, 2009 #1 N neilrr MB Enthusiast Joined Jul 20, 2004 Messages 7,421 Car Various. Do I need a special tool for the two little slots on the bottom corners or what?? TIA. Attachments W210 climate control 1.JPG 61 KB · Views: 83
Sep 29, 2009 #2 R renault12ts MB Club Veteran Joined Mar 5, 2009 Messages 16,674 Car 2005 W215 CL500. As you would the radio, using the same keys.
Sep 29, 2009 #3 Dieselman Banned Joined Jul 13, 2003 Messages 34,199 Car Peugeot 403 Convertible You might be able to prise the front covers off and use a couple of thin screwdrivers to release the catches then refit the covers once it's out. The latches need to be sprung inwards to release them.
Sep 29, 2009 #4 R renault12ts MB Club Veteran Joined Mar 5, 2009 Messages 16,674 Car 2005 W215 CL500. neilrr said: Do I need a special tool for the two little slots on the bottom corners or what?? TIA. Click to expand... How did you remove the radio??
Sep 29, 2009 #5 W Will Hardcore MB Enthusiast SUPPORTER Joined Jan 21, 2003 Messages 14,166 Location Surrey Car GL63 AMG / SL500 / Porsche 911 You can buy the MB radio/climate panel keys for something silly like under £1 each from your local dealer. Otherwise, some other radio keys might do - Blaupunkt/Becker or something - flat ones Will
Sep 30, 2009 #6 lynall MB Enthusiast Joined Jul 31, 2008 Messages 3,171 Location Kent Car The silver one. Iirc when i did mine i just removed the ashtray and the few screws behind it then removed whole panel leaving loads of room to get climate unit out without damaging anything. Someone had tried mine before and damaged the temp buttons both sides. Lynall
Sep 30, 2009 #7 OP OP N neilrr MB Enthusiast Joined Jul 20, 2004 Messages 7,421 Car Various. Thanks everyone, Removed it using some old, flat radio removal tools which I ground down thin enough to fit.
