Help me diagnose the problem
charles UK
Mercedes E-Class W210
Hi guys,
My E320 CDI 2002 blows hot air from the centre vents even though the setting control is set to cold, have you any idea before I take it in? Don't wanna get ripped off!
actuator
likely a worn broken linkage on actuator.i can put it on stardiag.if actuator then it
is about 11-12hours job to disassemble the dashboard and to put back
I think you will find it is your duo valve,which controls your hot and cold temp,the actuator fault described above would effect air flow and would be accompanied with a clicking noise.
search for duo valve on here,many post's.
Thanks for your responses, I have a heater pump come up on the computer when plugged in. Do you think that could be the cause?
I doubt it. That code always comes up even though it may work fine.
Tap the duo valve with a small hammer gently while turning the heater control wheels. It may in stick it.
